Insta360 GO 3S – The World’s Smallest Action Camera
sloganslogan
GO 3S INTRO
GO 3 INTRO
TINY POWERHOUSE
Small camera, huge potential.
Powerful 4K in a tiny body means a whole lot of creativity! Mount it anywhere, take it everywhere.
4K VIDEO2.7K VIDEO
Sharper, clearer, crisper.Social-media-ready.
GO 3S
GO 3
Powered by an enhanced chip with 50% more CPU computing power and a new wide-angle lens, GO 3S now shoots in stunning 4K. It offers nearly double the amount of pixels compared to 2.7K to capture every moment of life in sharp, clear detail.Record life in high-resolution 2.7K video with GO 3, ideal for sharing immersive POVs on social media.
MEGAVIEW FOV
Sharp and true from edge to edge.
Less distortion and straighter, cleaner edges. The new wide-angle MegaView FOV keeps everything looking picture-perfect and exactly as you saw it.
*Only available on GO 3S.
UltraWide FOVMegaView FOV
HANDS-FREE POV
A truly no-hands camera.
Go completely hands-free and live in the moment! Set it and forget about it for easy, ultra-wide POV shots.
EASY SWITCH
Switch aspect ratio in seconds.
Give GO 3S a twist and voilà! It really is that easy to change from horizontal to vertical shooting.
*Aspect ratio cannot be changed during a recording.
FLOWSTATE STABILIZATION
Bye-bye bumps.
Our signature FlowState Stabilization means seriously steady footage. Shakes, bumps or rolls are completely removed—perfect for when the action gets rough or walk-and-talk vlogs!
No Stabilization
MOUNT ANYWHERE
Limited only by your mind.
A tiny cam means easy mounting! With its magnetic design and three included accessories, you can film endless creative possibilities, with angles no other camera can handle. Think pets, helmets, or a fly-on-the-wall shot!
Easy to shoot.
QUICKCAPTURE
No more fumbling with settings while the perfect shot passes you by! Simply press the button on the front of the camera to start recording instantly, even when it's off.
GESTURE CONTROL
Stay in control with a simple gesture! Perfect for group snaps or loud environments.
VOICE CONTROL 2.0
True hands-free shooting and easy-peasy camera control with Voice Control 2.0. Just say the word to capture your next magic moment.
INTERVAL VIDEO
Live every moment, no distractions.
Family trips, bike rides, a day in the life of your pet? Automatically capture moments throughout your day or activity, then Auto Edit combines the highlights into one epic video, on beat to music.
LOCATE WITH Apple Find My
Easy relocation.
Track down your GO 3S via the Apple Find My network if you accidentally leave it somewhere. Go wild, go free, go straight back once you realize.
*To use the Apple Find My app to locate your GO 3S, the latest version of iOS, iPadOS, or macOS is recommended.
In-the-Box Accessories
Magnet Pendant
Snap on for easy first-person views.
Easy Clip
Clip on your cap or your pet's collar for awesome angles and fresh perspectives. Or attach it to the Magnet Pendant for flexible angle adjustment.
Pivot Stand
Stick it anywhere and capture unique angles. It's reusable, too!
*The Pivot Stand can only be stuck to surfaces that are dry and clean. Do not use in action scenarios.
Lens Guard
Twist and GO! Removable Lens Guard for worry-free shooting.
acc-item
acc-item
acc-item
acc-item
A
t
o
t
a
l
t
r
a
n
s
f
o
r
m
a
t
i
o
n
w
i
t
h
t
h
e
A
c
t
i
o
n
P
o
d
EXTENDED BATTERY LIFE
A supercharged duo.
Join forces with the Action Pod to film for a massive 140 minutes!
38minGO 3S Camera only
140minGO 3S Camera + Action Pod
*Tested in 77ºF (25°C) lab conditions at 1080p@30fps in Video Mode with screen and Wi-Fi off. Run time may vary in different conditions.
FLIP TOUCHSCREEN
Flip it, you're lookin' real good!
Shoot together with the Action Pod for perfectly framed selfies, flawless vlogging, or accurate handheld shooting.
REMOTE CONTROL & LIVE PREVIEW
Perfect shots wherever you mount.
Mount up the tiny cam and use the Action Pod to preview your shots and snap away like a pro.
*Recommended to use within 16ft (5m) in an open environment. Wireless interference may affect connection.
MAGNETIC MOUNTING
Mount up the camera or Action Pod.
The camera and Action Pod both fit the same Pivot Stand and Quick Release Mount, with a latch and magnet to secure them in place.
RUGGED ACTION POD
IPX4 splashproof.
Clouds looking a little grey? No need to hide inside. The Action Pod is IPX4 water-resistant against rain and splashes.
*The Action Pod is IPX4 splashproof only when the camera is installed in it. It protects against rain and snow, but should not be submerged in water or used for activities involving high-velocity water such as surfing and waterskiing.
WATERPROOF CAMERA
IPX8 waterproof up to 33ft.
Go catch those waves! Take the camera out of the Action Pod and dunk it down to 33ft (10m) for GO 3S or 16ft (5m) for GO 3. The perfect underwater companion.
*Included Lens Guard must be installed on the camera for underwater use.
WATERPROOF CAMERA
IPX8 waterproof to 16ft.
Go catch those waves! Take your GO 3 cam out of the Action Pod and dunk it down to 16ft (5m) without worry.
10m
5m
GO 3S
GO 3
QUICK READER
More storage? Easier transfer? Yes please.
Free up your camera's memory then keep on shooting! Plug in the camera to transfer files to a microSD card or edit directly on your phone. A faster, smoother way to film and edit.
UPGRADED AUDIO
Double the fun.
Record audio with the 2 built-in mics and capture vlog-ready audio from all around. Crisp, clear and immersive!
UNIQUE STATS DASHBOARD
Show off your stats.
Overlay stats like GPS, speed, and more from your Garmin device or Apple Watch. Get data-rich videos when you export thanks to our dedicated integration.
Get creative.
Motion ND
TimeShift
Slow Motion
Timelapse
Get immersive, motion blur-style shots without using an ND filter. Apply the the effect in-app with a tap.
Speed up time and space. Or at least pretend to.
If life is coming at you too fast, slow things down by 8x up to 200fps.
Watch the world go by. Shoot awesome timelapses, even at night.
INSTANT APP PREVIEW
Tap and play.
Snap a fresh video clip with your GO 3S—like magic, a notification zips straight to your phone, ready to preview and edit instantly.
*Only available on iOS.
App Preview
AUTO EDITING
Let AI do the work.
Auto Editing finds the highlights and edits them together on beat to music. You just choose your clips and put your feet up. It's definitely not cheating...
EXPORT IN ANY RATIO
One shot, any perspective.
Not sure where you'll share your shot? Or maybe you're posting on multiple platforms? Simply shoot in FreeFrame mode and you can choose your aspect ratio after recording!
MORE ACCESSORIES
Extend your setup.
  • insta360
    Quick Release Mount
    The versatile Quick Release Mount makes GO 3S compatible with loads of two-prong and 1/4" screw mount accessories!
    BUY NOW
  • insta360
    Monkey Tail Mount
    Wrap around a variety of objects and mount the world's tiniest camera everywhere.
    BUY NOW
  • insta360
    Dive Case
    Bring your tiny action camera and Action Pod with you underwater! Up to 60m waterproof.
    BUY NOW
  • insta360
    Vertical & Horizontal Action Mount Set
    A 2-prong frame for 3-prong accessories, unlocking new ways to shoot.
    BUY NOW
  • insta360
    Pet Harness Mount
    Comfortable harness for your pet's point of view.
    BUY NOW
  • insta360
    Magnet Pendant Safety Cord
    Strong rubber cord that prevents the camera from falling if it becomes unattached from the Magnet Pendant.
    BUY NOW
  • insta360
    ND Filter Set
    Get cinematic shots with balanced colors and contrast even on the brightest of days!
    BUY NOW
Powerful 4K in a tiny body.
Design your own look.
Personalize your camera with Custom Skins!
CUSTOMIZE NOW
Compare Models
4K30fps
Max. Resolution
2.7K30fps
Max. Resolution
1080p200fps
Max. Frame Rate
1080p120fps
Max. Frame Rate
Easy Switch
MegaView FOV
Interval Video
Gesture Control
Apple Find My
FlowState Stabilization & Horizon Lock
2.2" Flip Touchscreen
Remote Control & Live Preview
10m (33ft)
Waterproof (Camera only, not Action Pod)
5m (16ft)
Specs
Aperture
F2.8
F2.2
35mm Equivalent Focal Length
16mm
11mm
Photo Resolution
4000x2250 (16:9) 2880×2880 (1:1) 3968x1472 (2.7:1) 4000x3000 (4:3)
2560x1440 (16:9) 2560x2560 (1:1) 1440x2560 (9:16) 2936x1088 (2.7:1)
Video Resolution
Video 4K: 3840x2160@24/25/30fps 2.7K: 2720x1536@24/25/30fps, 2752x1530@50fps 1080p: 1920x1080@24/25/30/50fps FreeFrame Video 4K: 3840x2880@24/25/30fps 2.7K: 2720x2040@24/25/30/50fps 1080p: 1920x1440@24/25/30/50fps Timelapse 4K: 4000x3000@30fps (Export using Insta360 Studio for optimal quality.) TimeShift 4K: 4000x3000@30fps (Export using Insta360 Studio for optimal quality.) 2.7K: 2720x2040@30fps Slow Motion 2.7K: 2720x1530@100fps 1080p: 1920x1080@120/200fps Pre-Recording 4K: 3840x2160@24/25/30fps 2.7K: 2720x1536@24/25/30fps, 2752x1530@50fps 1080p: 1920x1080@24/25/30/50fps Loop Recording 4K: 3840x2160@24/25/30fps 2.7K: 2720x1536@24/25/30fps, 2752x1530@50fps 1080p: 1920x1080@24/25/30/50fps
Video 2.7K: 2720x1536@24/25/30fps 1440p: 2560x1440@24/25/30/50fps 1080p: 1920x1080@24/25/30/50fps FreeFrame Video 1440p: 2560x1440@24/25/30/50fps 1080p: 1920x1080@24/25/30/50fps Timelapse 1440p: 2560x1440@30fps TimeShift 1440p: 2560x1440@15/30fps Slow Motion 1080p: 1920x1080@120fps Pre-Recording 2.7K: 2720x1536@24/25/30fps 1440p: 2560x1440@24/25/30/50fps 1080p: 1920x1080@24/25/30/50fps Loop Recording 2.7K: 2720x1536@24/25/30fps 1440p: 2560x1440@24/25/30/50fps 1080p: 1920x1080@24/25/30/50fps
Photo Format
JPG DNG (can be exported to JPG via app or Studio)
INSP (can be exported to JPG via app or Studio) DNG (can be exported to JPG via app or Studio)
Video Format
MP4
MP4
Photo Modes
Photo, HDR Photo, Interval Photo, Starlapse
Video Modes
Video, FreeFrame Video, Timelapse, TimeShift, Slow Motion, Pre-Recording, Loop Recording, Interval Video
Color Filters
Standard, Vivid, Flat, Portrait
Weight
GO 3S: 39.1g (1.38oz) Action Pod: 96.3g (3.40oz)
GO 3: 35.5g (1.25oz) Action Pod: 96.3g (3.40oz)
Dimensions (W x H x D)
GO 3S: 25.6x54.4x24.8 mm (1.0x2.1x1.0in) Action Pod: Screen Folded: 63.5x47.6x29.5mm (2.5x1.9x1.2in) Screen Unfolded: 63.5x86.6x29.9mm (2.5x3.4x1.2in)
GO 3: 25.6x54.4x23.2mm (1.0x2.1x0.9in) Action Pod: Screen Folded: 63.5x47.6x29.5mm (2.5x1.9x1.2in) Screen Unfolded: 63.5x86.6x29.9mm (2.5x3.4x1.2in)
Color
Arctic White, Midnight Black
Video Coding
H.264
H.264
Max. Video Bitrate
120Mbps
80Mbps
Gyroscope
6-axis gyroscope
6-axis gyroscope
Compatible Devices
iOS Devices: Compatible with iOS mobile devices with chips A12 or above and iOS version 13.0 or above, including iPhone XS, iPhone XS Max, iPhone 11, iPhone 11 Pro, iPhone 11 Pro Max, iPhone 12, iPhone 12 Pro, iPhone 12 Pro Max, iPhone 12 mini, iPhone 13, iPhone 13 Pro, iPhone 13 Pro Max, iPhone 13 mini, iPhone 14, iPhone 14 Plus, iPhone 14 Pro, iPhone 14 Pro Max, iPhone 15, iPhone 15 Plus, iPhone 15 Pro, iPhone 15 Pro Max, iPad Air (2020), iPad Pro and newer iPad models. *To use the Apple Find My app to locate your GO 3S, the latest version of iOS, iPadOS, or macOS is recommended. Android Devices: Compatible with Android mobile devices that meet the following capabilities including: • Android devices with Kirin 990 and above chips, including Huawei Mate 30, P40 or newer models. • Android devices with Snapdragon 855 and above chips, including Samsung Galaxy S10, Xiaomi Mi 9 or newer models. • Android devices with Exynos 2200 and above chips, including Samsung Galaxy S22, S22 Ultra and newer models. (System should be Android 10.0 or above or HarmonyOS 2.0.0 or above.) Note: 1. Devices that do not meet the above requirements may still be able to use the app to control the camera. However, the performance of some processor-intensive and AI-powered features may be sub-optimal. 2. After testing, phones equipped with Qualcomm SDM765 5G chips have poor hardware decoding capabilities and are not supported for use, such as OPPO Reno 3 5G. 3. App installation requires a mobile phone with a 64-bit system. A 32-bit system does not support app installation.
iOS Devices: Compatible with iOS mobile devices with chips A12 or above and iOS version 13.0 or above, including iPhone XS, iPhone XS Max, iPhone 11, iPhone 11 Pro, iPhone 11 Pro Max, iPhone 12, iPhone 12 Pro, iPhone 12 Pro Max, iPhone 12 mini, iPhone 13, iPhone 13 Pro, iPhone 13 Pro Max, iPhone 13 mini, iPhone 14, iPhone 14 Plus, iPhone 14 Pro, iPhone 14 Pro Max, iPhone 15, iPhone 15 Plus, iPhone 15 Pro, iPhone 15 Pro Max, iPad Air (2020), iPad Pro and newer iPad models. Android Devices: Compatible with Android mobile devices that meet the following capabilities including: • Android devices with Kirin 990 and above chips, including Huawei Mate 30, P40 or newer models. • Android devices with Snapdragon 855 and above chips, including Samsung Galaxy S10, Xiaomi Mi 9 or newer models. • Android devices with Exynos 2200 and above chips, including Samsung Galaxy S22, S22 Ultra and newer models. (System should be Android 10.0 or above or HarmonyOS 2.0.0 or above.) Note: 1. Devices that do not meet the above requirements may still be able to use the app to control the camera, however, performance of some processor-intensive and AI-powered features may be sub-optimal. 2. After testing, phones equipped with Qualcomm SDM765 5G chips have poor hardware decoding capabilities and are not supported for use, such as OPPO Reno 3 5G. 3. App installation requires a mobile phone with a 64-bit system. A 32-bit system does not support app installation.
Live Streaming
Exposure Value
±4EV
±4EV
ISO Range
100-3200
100-3200
Shutter Speed
Photo: 1/8000 - 120s Video: 1/8000 - to the limit of frames per second
White Balance
Auto, 2000–10000K
Auto, 2000–10000K
Audio Modes
Wind Reduction, Stereo, Direction Focus
Audio Format
48 kHz, 24bits, AAC
48 kHz, 24bits, AAC
Bluetooth
BLE 5.0
BLE 5.0
Wi-Fi
5GHz 802.11a/n/ac
5GHz 802.11a/n/ac
USB
Type-C USB2.0
Type-C USB2.0
Storage
64GB, 128GB
32GB, 64GB, 128GB
Battery Capacity
GO 3S: 310mAh Action Pod: 1270mAh
GO 3: 310mAh Action Pod: 1270mAh
Charging Method
GO 3S: Action Pod Action Pod: Type-C
GO 3: Action Pod Action Pod: Type-C
Charging Time
GO 3S: 80% in 23 mins | 100% in 35 mins Action Pod: 80% in 47 mins | 100% in 65 mins
GO 3: 80% in 23 mins | 100% in 35 mins Action Pod: 80% in 47 mins | 100% in 65 mins
Run Time
GO 3S: 38 mins GO 3S + Action Pod: 140 mins *Tested in 77°F (25°C) lab conditions at 1080p@30fps Video Mode, screen and Wi-Fi off. Run time may vary in different conditions.
GO 3: 45 mins GO 3 + Action Pod: 170 mins *Tested in 77°F (25°C) lab conditions at 1080p@30fps Video Mode, screen and Wi-Fi off. Run time may vary in different conditions.
Use Environment
GO 3S: -4°F to 104°F (-20℃ to 40℃) Action Pod: -4°F to 104°F (-20℃ to 40℃)
GO 3: -4°F to 104°F (-20℃ to 40℃) Action Pod: -4°F to 104°F (-20℃ to 40℃)
